查看: 8428|回复: 1
如何在Revit族中创建风管连接件
发表于 2024-10-22 10:28:06 | 显示全部楼层 |阅读模式
我想实现在Revit族中创建一个立方体,基于立方体的一个面创建风管连接件。插件代码有两个操作,第一个创建实例,第二个创建风管连接件。
族中有一个嵌套公制机械设备族,族名称“族1”,族类型名称“族1”,族类型的ID是3165。这个嵌套族中仅有一个拉伸立方体。
族文件截图(视图中的立方体,是为了看嵌套族里的内容,手工创建的,插件运行时没有这个立方体):
族截图
族截图
代码如下:
[Transaction(TransactionMode.Manual)]
public class Command : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIApplication uiapp = commandData.Application;
        UIDocument uidoc = uiapp.ActiveUIDocument;
        Document doc = uidoc.Document;
        FamilySymbol symbol = (FamilySymbol)(doc.GetElement(new ElementId(3165)));
        Transaction transaction = new Transaction(doc, "abc");
        transaction.Start();
        FamilyInstance instance = doc.FamilyCreate.NewFamilyInstance(new XYZ(), symbol, StructuralType.NonStructural);
        transaction.Commit();
        var planar = GetPlanars(instance);
        if (planar != null)
            ConnectorElement.CreateDuctConnector(doc, DuctSystemType.Global, ConnectorProfileType.Rectangular, planar.Reference);
            MessageBox.Show("Succeeded");
        return Result.Succeeded;
    private PlanarFace GetPlanars(FamilyInstance instance)
        Options options = new Options
            ComputeReferences = false,
            DetailLevel = ViewDetailLevel.Fine
        GeometryElement geometryobj = instance.get_Geometry(options);
        if (geometryobj == null || geometryobj.Count() == 0)
            MessageBox.Show("获取面失败");
            return null;
        IEnumerator<GeometryObject> enumerator = geometryobj.GetEnumerator();
        while (enumerator.MoveNext())
            Solid solid = enumerator.Current as Solid;
            if (solid == null || solid.SurfaceArea == 0)
                GeometryInstance geoElem = enumerator.Current as GeometryInstance;
                if (geoElem != null)
                    GeometryElement enumerator2 = geoElem.GetInstanceGeometry();
                    IEnumerator<GeometryObject> enumerator3 = enumerator2.GetEnumerator();
                    while (enumerator3.MoveNext())
                        solid = enumerator3.Current as Solid;
                        if (solid != null && solid.SurfaceArea > 0)
                            foreach (Face face in solid.Faces)
                                if (face is PlanarFace)
                                    return (PlanarFace)face;
        return null;
运行时,创建实例没有问题,获取实例几何的面也没有问题。调试截图如下:
获取几何面
获取几何面
创建风管连接件时出错,提示平面引用有问题
调试平面引用出错
调试平面引用出错
Revit错误提示截面
Revit错误提示截面
向各位专家请教,我该如何创建这个风管连接件?
发表于 2024-10-23 15:55:09 | 显示全部楼层
这里需要改为True
            ComputeReferences = true,
