查看: 15415|回复: 0
橄榄山快模免费版教程-----轴线生墙出问题
发表于 2018-2-28 10:26:17 | 显示全部楼层 |阅读模式
[Window Title]UIRibbon - 创建墙发生错误[Main Instruction]用Ctrl + C来复制下面异常信息,直接黏贴到邮件中发送给橄榄山glsbim@hotmail.com请一并在邮件中说明在什么条件下出现此错误。非常感谢您提交信息! The given value for height must be greater than 0 and no more than 30000 feet.Parameter name: height   在 Autodesk.Revit.DB.Wall.Create(Document document, Curve curve, ElementId wallTypeId, ElementId levelId, Double height, Double offset, Boolean flip, Boolean structural)   在 VerTools.CreateWall(Document doc, Curve curve, WallType wallType, Level bottomLevel, Double height, Double offset, Boolean flip, Boolean structural)   在 cmd405.Execute(ExternalCommandData commandData, String& messages, ElementSet elements)[关闭(C)]
A transaction or sub-transaction was opened but not closed. All changes to the active document made by External Command will be discarded.
